8 3/4 axel ?
flathead31coupe
indianapolis indiana
are 8 3/4 axels the same length... I was given a set of axel one was supposed to be an adjustable one... the I was going to put green bearings on both.. but was give two of the same non adjustable ones...
Are you speaking to the OE axles??? I believe all of the OE Axles for A body are the same length! Not sure about aftermarket!!
Sealed replacement ball bearing, rather than the tapered pin timken style original bearing.
They last about a day, road racing. Got 400k on a set of 1967 Timkens, still like new. Ask Green Bearings the specs on axial loads on their bearings. I agree with you that normal driving should be good for 100k especially straight line. Everything is relative...
