8 3/4 brake parts
Sorry, it is an a body rearend I am swapping to BBP. Bought everything needed to rebuild completely minus brake parts.
Ok, this is important: If you are using aftermarket or cut down B/C/E body axles, you need the B/C/E body backing plates and drums. If you are using REDRILLED A body axles, you need A body backing plates and redrilled drums. The stock A body axle had a different offset and the backing plate was offset to match it.
