8 3/4 Custom Width Housing Supplier?
kend
GA
I need an 8 3/4 housing in a custom width, any suggestion on who to call? Thanks
Mosier's 8 3/4 housing looks like a 9" to me. LOL I just checked with Dr Diff but I don't see any housings.
I looked at those and their "8 3/4" is a 9" with an 8 3/4 flange welded on. I want a true Mopar 8 3/4 housing. Thanks
If you can find a OEM housing you can send it to them and they will custom build it for you. Any length will work since you want it custom. B body housings can sometimes be had for much less than A body.
A local, reputable driveshaft or 4 wheel drive shop "may" have the capability or connections to get a rear narrowed.
Might be a longshot, but what width would you be looking for - in case someone may happen to have one. Otherwie, as mentioned, start out with a wider version to be cut down due to the cost of an OEM A-body width.
Moser, Strange, Dr. Diff can probably do it, but shipping would add up quick.
seems totally backwards to me, the beauty of the 8.75 (at least to me) is the efficiency of the center section compared to the 9". I have heard the argument of welding 9" housing ends onto a 8.75 housing which makes more sense to me (if you want greater aftermarket brake support) but never the other way around.
