8 3/4 dimensions ?????
cuda67bnl
Hey guys,
Can someone tell me the dimensions for an A-body 8 3/4?
I know the spring perch measurements are 43 inches, and flange to flange is is 52 1/2, but what is the overall dimension from outer edge of axle to outer edge of the other axle?
I'm looking at a rear that's supposed to have been narrowed to factory A-body specs. It has cut down and resplined C-body axles and brakes.
Thanks.
Just found this yesterday. Is this what you're looking for?
I need the overall width of the complete rear end. That chart doesn't give it, plus some of the specs on that chart are wrong too. Thanks though.
I have 2 sitting here, both are missing the drums, so it made the mearsuring that much easier.
Using a square (straight edge) from outer axle to outer axle they both measured 57".
Hope this helps.
All the best.
