8 3/4 flange gasket question
jwsewell
Active Member
Vancouver, WA
Ok I understand were the inner axle seal goes. (inside the tube). My question is about the flange seals. I have two Steel shim gaskets and two white foam gaskets.
Is the correct installation order ...
steel shim > backing plate > foam gasket > axle retainer flange
