8 3/4 identify
nick455440
Florida
thinking about picking up a 8 3/4 rear end, has a 489 case posi 3.23, but looked at several sites and cant figure out what it came out of, it’s 48.5 inches from center perch to center perch, any ideas? Mainly want it for the chunck but also was to see how sellable the housing and axles will be that I will not need, thanks
Are the purches on the top of the housing tubes = truck (or van?)
A local guy buys housings for about 150.00 he modifies them to your specs axles dont seem to sell. Brake parts will sell.
Good call, looked back at a pic and they do look to be on top, guy was positive it came out of a bBody, guess I was scratching my head over the tape measure missed the obvious, thanks
Rear Axle widths, drum-to-drum: Sorted by body-type/model
A BODY ’66-’72: 57-1/8″
B BODY ’62-’63: 58-1/2″ (And ’64 Max Wedge)
’64: 60-7/8″ (Exc.Max Wedge)
’65-’67: 59-1/2″
’68-’70: 60-1/8″
’71-’74: 63″
’71-’73 wagon: 64-3/8″
C BODY ’65-’69: 61.75″
’70-’71: 63.0″ (Chrysler & Fury)
’70-’73: 64-3/8″ (incl. ’69 wagon)
IMPERIAL ’65-’66: 61-15/16″
’67-’69: 62-5/16″
’70-’71: 59-3/4″
’72-’73: 64-9/16″
E BODY ’70-’74: 61-5/8″
A100 ’65-’70: 61-3/4″
D100 ’65-’71: 63-15/16″
’72-’74: 64-3/8″
8-3/4″ Axle Shaft lengths, from the splined end to outside flange end:
A BODY ’66-’72: 27-11/16″
B BODY ’65-’67: 28-7/8″
’68-’70: 29 3/16″
’71-’74: 30-5/8″
’71-’73 wagon: 31-21/64″
C BODY ’65-’69: 30″
’70-’71: 30 5/8″ (Chrysler & Fury)
’70-’73: 31-21/64″ (incl. ’69 wagon)
IMPERIAL (Large Bolt Pattern) ’65-’66: 30-1/8″
’67-’69: 30-5/16″
’70-’71: 29″
’72-’73: 31-7/16″
E BODY ’70-’74: 29-31/32″
A100 ’65-’70: 30″
D100 ’65-’71: 31-1/8″
’72-’74: 31-21/64
8-3/4″ Housing Widths, from one end to the other end:
A BODY ’66-’72: 52-5/8″
B BODY ’62-’63: 53-1/4″ (And ’64 Max Wedge)
’64 : 55-5/8″ (Exc. Max Wedge)
’65-’67: 54-1/4″
’68-’70: 54-15/16″
’71-’74: 57-7/8″
’71-’73 wagon: 59-7/16″
C BODY ’65-’69: 56 3/4″
’70-’71: 57 7/8″ (Chrysler & Fury)
’70-’74: 59 7/16″ (incl. ’69 wagon)
IMPERIAL ’65-’66: 57″
’67-’69: 57 3/8″
’70-’71: 54 3/4″
’72-’73: 59 5/8″
E BODY ’70-’74: 56 31/64″
A100 ’65-’70: 56 3/4″
D100 ’65-’71: 58 5/16″
’72-’74: 59 7/16″
Spring perch distance/widths (center-to-center)
A BODY ’66-’73: 43″
B BODY ’62-’70: 44″
’71-’74: 47.3″
C BODY ’65-’73: 46″
E BODY ’70-’74: 46″
Dana 60 rear axle dimensions and specifications
Bodystyle
Housing width Flange to flange Spring perch distance Sure-grip type Yoke type
'66 B-body
54-1/4" housing 59-3/8" axle flange to flange 44" perch 23 spline Power-Lock Sure-Grip 1330 U-bolt yoke
'67 B-body 54-1/4" housing 59-3/8" axle flange to flange 44" perch 23 spline Power-Lock Sure-Grip 1330 strap yoke
'68-'69 B-body 54-15/16" housing 60-1/16" axle flange to flange 44" perch 23 spline Power-Lock Sure-Grip 7290 yoke
'70 B-body 54-15/16" housing 60-1/16" axle flange to flange 44" perch 35 spline Power-Lock Sure-Grip 7290 yoke
'71-'72 B-body 57-7/8" housing 63" axle flange to flange 47.3" perch 35 spline Track-Lock Sure-Grip 7290 yoke
'70 E-body 56-31/64" housing 61-5/8" axle flange to flange 46" perch 35 spline Power-Lock Sure-Grip 7290 yoke
'71 E-body 56-31/64" housing 61-5/8" axle flange to flange 46" perch 35 spline Track-Lock Sure-Grip 7290 yoke
All measurements are from drum to drum: Sorted by length
1966-1972 A-body 57-1/8″
1962-1963 B-body 58-1/2″
1964-1967 B-body 59-1/2″
1970-1971 Imperial 59-3/4″
1968-1970 B-body 60-1/8″
1970-1974 E-body 61-5/8″
1965-1969 C-body and 1965-1970 A100 Vans 61-3/4″
1965-1966 Imperial 62″
1967-1969 Imperial 62-5/16″
1970-1971 C-body and 1971-1974 B-body 63″
1965-1971 D100 pickup 64″
1969 C-body wagon and 1971-1973 B-body wagon 64-3/8″
1970-1973 C-body and 1972-1974 D100 pickup 64-3/8″
Truck and van 8 3/4” stuff is actually a pretty good sell. Take the center and list the rest on the truck sites, all that stuff will sell.
