v8val
v8val
Hi all, I don't post on here much, i read a lot, but am hoping you can help anyway. I'm putting a sure grip in my 489 centre, and will use a solid spacer. I can't find the exact info regards using shims. Is the main use of the shims to set bearing preload? Or is it to set pinion depth as compared to the ring gear? I have a factory manual to use. But obviously this is a bit different. Do i just set the pinion with shims for preload, then put the centre in and adjust that for meshing the gears?
Haven't done it before, and shops here want over 500 bucks for doing it. Cheers all, Ben.
