furydan
not so junior member
So I just installed an 8 3/4 in my 65 barracuda. I bought it from a guy who had it in a 70 something dart. The axles were aftermarket, with the small bolt pattern. Are the axles shafts supposed to be the same length as each other or is one bigger than the other? I found adjusters on both left and right bearing retainers on the axles..I thought the adjuster was only on the right side.
The unit is a clutch type sure grip with the smaller u joint. Any one know how old this thing might be. As far as I can tell, they changed from the clutch type to a spring assisted sure grip around 69/70.
What happened was that the adjuster on the left side backed all the way out after running the car for a few miles. The adjuster got all messed up and wont thread back in to the bearing retainer.
Do I really need an adjuster on both sides? Where can I get a new bearing retainer for the left axle? 1 without the adjuster.
Dan
Dan
