how to set up end play - sure grip rear end - pulled axles and can see the end of the other axle.It seems missing something . change to sealed bearings - help
Sounds like you're missing the thrust button that is needed only if you are still using the original tapered bearings. Did you mean you changed to the "Green" sealed type bearings? If you have then no end play adjustment is necessary. If not, just find yourself a thrust button for your setup and then adjust the endplay. Geof
