8 3/4 rearend
terzmo
Pendleton,NY
Rating - 0%
0   0   0
8 3/4 rearend minus drums and brakes...has 741 case with 323 suregrip. Small bolt pattern...Off an A body...72 demon...700
also 8 3/4 center section 489 case...430 suregrip....500.00
will mix and match..outside of Buffalo NY
Not completly sure but I believe the sure grip axles differ from the open, I would also think but don't know, that the axles will be thicker on the 8 3/4. I am sure many people on here know for sure.
There are some 8 3/4 axels that will fit in but need to be cut down a bit. I'm not possitive about your swap but I would lean towards yes unless the gear spacing is different from a 7 1/4 to an 8 3/4 centerchunk
Hello
Will you ship to Memphis Tenn? I'll pay the shipping. Is the spacing between the backing plates around 51.400"? What is the spacing on the spring hangers?
Old School
