[FOR SALE] 8 3/4 suregrip
terzmo
Pendleton,NY
Rating - 0%
0   0   0
Just removed from my 67 R/T...complete rearend, drum to drum, 11 inch drums...391 suregrip..741 case..new green bearings...includes brake lines and e cables...just bolt in and enjoy....works perfect..no disappointments....removed for a dana....440 coming out for a hemi...so I'm upgrading..Outside Buffalo NY $800.00
will consider selling everything except center section at reduced price
will NOT sell center section alone
I'm Very interested... Will this fit in my '65 Cuda? If you provide me with measurements from outside to outside of breaks and outside to outside of perches I'll compare
Hi there...
Is this still for sale?
If yes, will it fit my 65 Cuda?
Is it 4" or 4.5" bolt pattern?
Spring perch c to c measurement is ?
I will pick up near Cdn Border in US side...
Thanks
Ray
It's a b body 8.75 rear so it's a BBP 5x4.5 pattern.
You will need to move the pearch in a bit to be correct but you don't have to. It require higher backspaced wheel to fit into an A body but plenty of people use b body rears in their a bodies.
There are both BOLT Patterns for the 8 3/4 available.
That in itself does not mean it's not necessarily for a "B" body.
I am looking for a 4.5" bolt pattern anyways....
I guess I should also ask for the following additional dimensions;
Length Overall...?
Distance between the Back-Plates...?
My 65 Cuda has the following approx. dimensions now;
C to C on the Spring Perch - 43.25"
Inside Hub to Inside Hub - 52.5"
Back-plate to Back-plate - 50.75"
Hopefully it will be close...
I found one with a 56" Hub to Hub - won't fit....lol
