8 3/4 U-bolt question
VintageRacer67
1967 Dart GT 318/Auto
Orange County, CA
Hello FABO. I just purchased used shock plates and U-bolts for a 8 3/4 rear from a member here. I have a quick question. I received 2 which are flat at the top of the “U” and two that are not. I know on my 7 1/4 rear, all the U bolts looked the same (flat on top). Will these work for the 8 3/4? Or are two of U bolts incorrect?
Thanks FABO!
The OEM are flat on the top with x's on the under side for extra side hold I believe. The others are after market from a spring shop. They will all work just look different. put one of each on either side and no one will know . use the OEM on the inside so you don't notice the aftermarket style.
also, many folks get super excited about torqueing them down and they crank 'em. Tighten them in a crossing pattern, snugging them up as you go. Maybe 20 ft. lbs, then go to about 40-45 lbs. You only want about 45 ft lbs max.
DO NOT use the non flattened ones.
The flats distribute the point load of the U bolt over a larger area.
You WILL crush the housing tube.
This is crush NOT wear
Yeah, that was my first thought when I saw them. Obviously, it would have been cheaper to produce them round, but Chrysler decided to make them flat for a reason. To spread the surface area out so it wouldn’t damage the housing tube. Thanks for confirming what I was worried about.
I guess I will junk these and try to find 2 more OEM ones. I should have just ordered new ones from the start. Lesson learned.
This is crush, NOT wear
Wow must have been installed with a 3/4 impact. The calvert cal track kit comes with round u bolts. I never squashed a housing like that . Lift kits for trucks also round u bolts. Someone either over tightened them or they came out of the Dukes of Hazzard's General Lee bridge jump car
Okay. Maybe the round ones will be fine. Maybe not. If I can find 2 more OEM ones for a decent price, I’ll get them and use them just to be safe. The price I paid was worth the shock plates alone, so I’m good either way.
I've used both no issues.
I bought the housing from photos, I did not know it was even possible.
But even in the FSM it cautions about over tightening. The tubes are rolled steel to form a tube, then further pressed / stamped / forged to form all the shapes needed.
Unlike a Dana 60 or the 7 1/4 with relatively thick wall tubing pressed / tach welded into a cast center.
The round ones will be fine. Almost every manufacturer uses the round ones. Even on camper trailers and every other trailer out there. I do agree the flat ones will distribute the clamping force over a wider area. Kim
