8 3/4 with 323 trac lock fluid recommendation
cherokeechief79
new jersey
its in a 68 barracuda all just rebuilt and narrowed 3 in per side.
it has a gutted center in it now and i want to put the rebuilt center in it so we can weld the perches on it.
what fluid should i use?
i want to buy something locally if possible like autozone.
thanks
80w90 with the friction modifier will be just fine. Since you are up in the cold country, I would use the 80w90 versus the 80w140.
can i get this with the friction modifier in it already?
im trying to find a name or part number so i can make a few calls.
looks like most have valvoline
Track Lock is Ford nomenclature. Mopar is a sure grip.
thanks
Do you have O'Reilly's?
https://www.oreillyauto.com/detail/...al-gear-oil-80w-90-1-quart/cas0/8090?q=80w-90
Or Advance Auto?
https://shop.advanceautoparts.com/p...il-conventional-75w-90-1-quart-vv820/11301050
Both of these have limited slip additive already in them.
I didn't see anything on Autozone's site, but if it says limited slip on the bottle, you're good to go.
