BigRichieO
Colorado Mopar
While cleaning a shelf in the garage I found a set of 8.5mm spark plug wires that were for a Ford Bronco that I used to own. I needed only the coil wire for a fix on the Bronco so I was wondering if I could use the 8.5mm wires on my Dart. The Dart is a 340 with electronic ignition, and everything else stock. The current wires are 7mm, so would the 8.5's be better or will there be any difference? Let me know what you think.
