Does anyone have a source for a new 3.23 ring and pinion? I have a 489 case on a 1974 Dart Sport. Other ratios are commonly available but cannot find a 3.23. Thanks.
The 3.23 gear set is the most common gear set out there for the 8.75 center section.Phone randy,s ring and pinion and you will have your geat set and a rebuild bearing set,mrmopartech
