1. ram45red
    ram45red Well-Known Member
    568
    8
    Oct 18, 2011
    kershaw sc
    Local Time:
    7:42 AM
    Any problems redrilling small bolt pattern 8.75 axles out to large bolt patterns for use on a street car ?
  2. Daves69
    Daves69 Well-Known Member
    5,324
    3563
    Feb 20, 2011
    WestOfChi
    Local Time:
    6:42 AM
    Holes need to be precision on locations. Likely would need to use screw in studs. Depending on the stud head, clearance may get tight on the parking break strut. Seen some flanges that didn't have the old stud holes filled.
  3. 72Dart6pack
    72Dart6pack Harder Better Faster Stronger.
    4,119
    4207
    Feb 1, 2016
    Roseville Michigan
    Local Time:
    7:42 AM
    Your putting your life at risk redrilling so close to the outer edge. Now watch! Nine people will throw up red flags & say they have done it. 5 people will agree with me. And the topic will somehow change to what cylinder heads are you running? Do it safely & buy the correct axles. Just my 2 cents.
    • Like Like x 5
    • 72bluNblu
      72bluNblu FABO Gold Member FABO Gold Member
      11,228
      5752
      Nov 28, 2008
      NorCal
      Local Time:
      4:42 AM
      :rofl:
      But seriously!!!!
      Yes, people have done it, your results may vary! Personally I'd just buy new axles from doctor diff.
      The other issue with re-drilling the axles is that you must use your SBP brakes still and re-drill the drums as well. You can't use the standard big bolt pattern 10x2.5" brakes because the offset on the axles is different from SBP to BBP, so the offset on the backing plates is different etc. So, if you re-drill the axles you must also re-drill your drums and re-use your current SBP brakes.
    • ram45red
      568
      8
      Oct 18, 2011
      kershaw sc
      Local Time:
      7:42 AM
      That has been my thoughts all along. just considdering them for a quick fix going to buy Mosser or Strange When buget allows .Needing to swap from 7.25 to 8.75 don't have axles yet .
    • marksmopar1
      marksmopar1 Well-Known Member
      664
      146
      Feb 21, 2014
      Winnipeg, Canada
      Local Time:
      6:42 AM
      I did this, no issues, but yes I still used the brakes that came with the car/axle...and I used the 7/16 studs , but it gets real close or to close to the flange edge when using 1/2 studs like on the 4 1/2 X 5 wheeled cars.
    • vitamindart
      vitamindart Well-Known Member
      1,263
      352
      Jun 11, 2010
      Vernon,Wisconsin
      Local Time:
      6:42 AM
      i'm with Dave & 72, do yourself a favor and buy new axles. you can get them ordered to run your current brakes or upgrade to the B & E body rears.
      if your brakes are old, I would upgrade as the a body rear drums can be a pita to find new sometimes. plus more brakes are always a good thing IMHO.
    • dano
      dano Evil Handy Man
      3,516
      1402
      Aug 22, 2005
      Gresham, Oregon
      Local Time:
      4:42 AM
      In the image above, look at how much smaller in diameter and thinner the SBP flange is compared to the LBP flange. Even the shaft shank it's self is smaller. As inexpensive as they are I'd buy new axles just to upgrade to something newer, stronger and you can get brake parts easier for.
    • marksmopar1
      664
      146
      Feb 21, 2014
      Winnipeg, Canada
      Local Time:
      6:42 AM
      Yup, buy the correct new axles, I did mine at a time when the large Bolt pattern wasn't as available....long ago. Today I would just buy what I wanted...easy
    • famous bob
      famous bob mopar misfit
      18,402
      7764
      Aug 14, 2011
      okla
      Local Time:
      6:42 AM
      If ur running a stock small engine and don`t plan to put in big power in it, dooooo it !
    • Jimacuda
      Jimacuda Well-Known Member
      1,862
      624
      Nov 10, 2006
      Phoenix AZ
      Local Time:
      5:42 AM
      my 69 'cuda (A57) had a nasty 440 4 speed in it before I got it and it had the redrilled 8.75 axles. Didnt see anything off when I rebuilt the rear end, axles looked fine.
      That said, I'm not reusing them in that rear end. Replaced them with a lbp big brake offset axles from DrDiff to use on the Demon.
      I dont like the lack of center register fit for the large bolt pattern steel wheels I'm running and dont want to use a spacer ring.
    • carguy47
      carguy47 Well-Known Member
      511
      40
      Feb 5, 2015
      Phoenix, Arizona
      Local Time:
      5:42 AM
      Yeah, I agree. Just buy new Dr. Dif axles. Not worth the hassle and time.
    • sccachallenger
      sccachallenger Well-Known Member
      255
      90
      May 18, 2015
      north carolina
      Local Time:
      7:42 AM
      If you must, screw in only, consider 7/16" will give you a little more metal around the hole.
      And hey gm used 7/16" studs on most of their cars, so I guess it'll last a little while!
    • belmateo
      belmateo Well-Known Member
      1,835
      253
      Mar 29, 2008
      Belmont, California
      Local Time:
      4:42 AM
      I did mine by welding in the original bolt holes before drilling the new ones and converted to Disc brakes at the same time. A car I bought years ago had them just redrilled, no problem.
      Do what makes you feel most comfortable, it is your car.
    • Oldmanmopar
      Oldmanmopar Going left turning right FABO Gold Member
      9,009
      5466
      Jan 8, 2009
      Danielsville Pa. 18038
      Local Time:
      7:42 AM
      Using the older axles 67 early 68 is the way to do it.
      They do not have the balance holes. Drill for 1/2 20 ARP bolts and tig weld from behind. The heads are also machined to stud head thickness. to clear the Parking brake strut. Use the original drums and backing plates.
      Have the drums and axles indexed on a mill. and use a fixture to tap holes in axle. It works well and did run slicks with no problems years back when 15 " was hard to find in Small bolt pattern. You will have to pull all five through at one time for them to fail. Never saw it happen in all my years of Drag racing and we never filled the holes. Road racing or hard turns with today's sticky street tires would scare me ?????. Everyday car for just appearance on street tires with steel rims and tapered lugs you will not have a problem.
      I have seen the center rip out of cragars before the studs pulled using slicks.
      Now lets talk Cylinder Heads
      • Agree Agree x 2
      • Like Like x 1
      • 71 Valiant
        71 Valiant BB Scamp
        16
        0
        Mar 20, 2013
        Chicago Burbs
        Local Time:
        6:42 AM
        Good idea if i can find someone to drill it for me
