8.75 driver side axle flange is different?
Transmission and Drivetrain Tech
  1. Righty Tighty
    Righty Tighty FABO Gold Member FABO Gold Member
    870
    627
    Aug 16, 2019
    Sahuarita, AZ
    Local Time:
    1:09 AM
    Why is the axle flange different on this 8.75?
  2. dadsbee
    dadsbee FABO Gold Member FABO Gold Member
    886
    1834
    Nov 25, 2020
    Penetang, Ontario
    Local Time:
    4:09 AM
    Right side is your adjuster to set axle end play...
    • Agree Agree x 6
    • forphorty
      forphorty Well-Known Member
      746
      345
      Jan 19, 2006
      Local Time:
      3:09 AM
      end play adjuster
      • Agree Agree x 2
      • 694spd
        694spd Well-Known Member
        1,061
        379
        May 2, 2014
        Upstate NY
        Local Time:
        4:09 AM
        The axle adjuster is supposed to be on the passenger side. They are reversed based on your description and pictures..
        • Agree Agree x 3
        • Disagree Disagree x 1
        • Righty Tighty
          870
          627
          Aug 16, 2019
          Sahuarita, AZ
          Local Time:
          1:09 AM
          Thanks everyone.
          And yes, I mixed up the ends of the housing. Sorry about that.
        • Righty Tighty
          870
          627
          Aug 16, 2019
          Sahuarita, AZ
          Local Time:
          1:09 AM
          I was looking at the spring perches, but apparently on this housing they are on top of the axle tube. This came from a 70s pickup.
        • sccachallenger
          sccachallenger Well-Known Member
          281
          104
          May 18, 2015
          north carolina
          Local Time:
          4:09 AM
          I guess you're gonna narrow it?
        • Righty Tighty
          870
          627
          Aug 16, 2019
          Sahuarita, AZ
          Local Time:
          1:09 AM
          No, I already have an 8.75 A body housing, I’m just pulling the carrier from this one for the Sure Grip.
          Incidentally, this housing is available for anyone in the southern AZ area!
        • famous bob
          famous bob mopar misfit
          19,565
          8625
          Aug 14, 2011
          okla
          Local Time:
          3:09 AM
          Mine was stock on the drivers side from the factory !-1966 belvedere .
        • 694spd
          1,061
          379
          May 2, 2014
          Upstate NY
          Local Time:
          4:09 AM
          If you check my post, I said "supposed" to be on the passenger side. Meaning that there could be other possibilities found.
          Hey, I bought a B-Body 8-3/4 axle a few years ago from a friend's estate and I found that there were adjusters on both sides.
          I sold it the same way that I found it, but I knew if having two adjuster would create a problem or not.
        • famous bob
          19,565
          8625
          Aug 14, 2011
          okla
          Local Time:
          3:09 AM
          ma mopar had a lot of inconsistancies for sure.
          I bought a new 68 barracuda fastback in 1968 , I didnt have enough sense to keep it or the paperwork , the window tag stated that they were out of 383`s when it was built and had the roadrunner engine , I didnt know any better , and have only heard of ''one'' other , they said it was rated at 330 h.p. because of the drivers side exhaust manifold , versus a b body manifold . =5 h.p. diff.
          I do know it was almost uncontrollable on the tires back then , about like my buddies 66 chevy 11 w/ a 365 horse 327 in it .
          • Like Like x 1
          • str12-340
            str12-340 FABO Gold Member FABO Gold Member
            1,844
            1146
            Dec 26, 2012
            Vashon, WA
            Local Time:
            1:09 AM
            Can use 2 adjusters to slightly move the axle flanges from side to side to correct for off center housing for tight tire clearance on one side only...
