8.75 pinion torq specs.
....................Its not really a torque spec on the pinion nut, its more of a rotating tork of the yoke..........did u install a new crush sleeve?.......or new bearings?............nothing new....used everything about 10 inch pounds rotating tork................kim.........
its a newly setup unit with new parts. i changed yokes afterword and dont want to screw it up i did not setup the unit.it hasent been run yet. I can manage the rotation torque measurement. thanks.any more tips i am all ears.
A crush sleeve is a one time use!
Install a new crush sleeve and do it right,or install new pinion bearings later on or after it fails.
I think a new crush sleeve is cheap insurance.:D
