80/20 Rule
Exactly. I put my 451 together with mildly massaged 516 heads (larger exhaust valves, hardened seats, bowl blend) because I had them and wanted to get the car on the road. Despite the poor match to the 272@.050 cam. Low end isn't much (not surprisingly) with a 2.66 four-speed and 3.91 gears. So far I'm just breaking it in, putting around, and tuning, so the presumed fall-off at the high end when it really starts breathing was an acceptable temporary trade to get it on the road.
Meanwhile, I also had Dwayne Porter do a Stage 1 job on some Speedmaster aluminum heads, which are now on the shelf waiting to go on once the heat/humidity breaks and allows working in the garage! 295 cfm @ .650 should wake it up :)
Wow that's impressive. How are the other lift numbers?
No idea what the 516's flow, but I'd be surprised if they make 250 cfm.
For the Speedmasters, here are the numbers from Dwayne.
OOTB:
Lift——-in/ex
.100— 67.5/53.5
.200—137.2/101.2
.300—202.8/138.3
.400—241.2/160.3
.500—256.1/171.2
.550—262.5/174.4
.600—269.2/176.9
.650—269.2/178.1
.700—269.2/179.3
After:
Lift—— in/ex
.100—- 72.5/62.7
.200— 148.8/105.4
.300— 217.6/143.9
.400— 261.8/171.5
.500— 286.1/190.5
.550— 290.5/197.8
.600— 292.4/203.7
.650— 293.5/208.6
.700— 294.3/212.2
Probably more suited to a slightly smaller cam, but I always wanted to run a Mini-Express mushroom setup :)
Here is my list of questions to your question :)
  • Is it really 20% left on the table? How do we know?
  • Whatever the % that IS left on the table, what's it cost to get it????
  • Whatever the cost is to achieve that last % number, what if we spent it on another part(s) to increase more power be worth more power than the money spent to get the last % of power left on the table?
I would really like to sit at this table...the one with all the power left on it...it sounds cool....maybe I'll just install this table under my hood and go.....what do you think? :D
I don't know what table you're sitting at, but there's not much left on my table. lol
only about 2% left after i leave the table, better pick another table :D
