[FOR SALE] 83/4 housing
moparraceman
mansfield ohio
NO A BODY HOUSING have several 83/4 housing blasted and painted ready to use, or cut to size you need, have 2pcs 59 " from end plate to end plate , one has no spring perch pads, perfect one to cut to 52 5/8 abody lenght $125 for housing new SP PADS about $20 bucks at summit also have another 59" with pads at 44 " with axles $225 or housing alone $150 also another one at 56 1/2-44" SPPads $150 and couple more.will be at norwalk end of month with a awap space lots of new and used parts at less than new prices here are a few here are a few new parts iam bring s/b comp timing chain set double roller $68 ,melling oil pump drive shaft with bushing $55 ,new s/b wires,$45yellow accel coil 45,accel cap $ 45 , several new gas lines with pressure gage for dual feed holley 68,after market 83/4 big yoke $ 50 also used small yoke $45 also voltage reg constant out put with wiring hardness. $ 45 90 degree oil filter adapter$80, excellent pair of 83/4 shock plates with part number stamp on $100 .# 741 and #489 cases. new small block alum intake air cap style fits all s/b and lots summit $475 $250 ,also new pro form distributor kit, with resister,wiring,orange box,distributor , $160 come check it out mopar nats #2 if any one is interested in any of this stuff if you prepay, i will hold it for you, and deliver it to norwalk for free thanks snubber $50 steering wheel $30 electronic distributor with wires s/b $75 all small items plus shipping
