833 bell housing questions
71dusterdan
rockford il
Hey fellas, been playing around a lot lately trying to determine a way to use magnum injection, yet still use my 833. So starting from the top of my current idea, what size flywheel is used in say a Ramcharger. Looked it up on Rockauto, the only clue I got, was it used an 11' clutch. Would that be a 143 tooth flywheel? If so, why couldn't I use the Ramcharger bellhousing?
Thanks
don't know. if the bell was for a "truk" 4 speed and not the A833 OD trans you the 833 prolly won't bolt up
the ones with larger flywheel prolly won't fit a pass car body. ya havta match the flywheel to the bell= larger wheel than car
Believe I had the 11" behind the 360 in my '77 Ramcharger. Guessing 143 teeth. I know there are BB housings that accept the 11" and 833 combo not sure about SB though.
Check with the guys on......
http://www.fortrucksonly.com/
http://ramchargercentral.com/
Never had to change that clutch by the way! 143K miles, tow, flat tow, and snow plow. It just rusted and ate headers!
Trucks use the 143 tooth flywheel/11" clutch set up. The truck bellhousing wont bolt up to an 833 transmission, the bolt holes aren't even close and there isn't meat to drill and tap new ones.
