CopperheadDart
This is a 1966 833, with 26 spline output. Everything you see in the first pic-
Smallblock bell housing, clutch fork, Flywheel, tunnel hump, pedal set, ball studs, etc. The Z bar isn't correct for A body, but could probably be fabb'ed up to work. I may have an A body Z somewhere. I also may have a slip yoke to fit also. Buy yourself a clutch, shifter, shifter rods, slip yoke, and start rowing some gears.
I'll try to get more photos later if there's interest. Asking $1600 for everything, not separating at this point.
Also have a smallblock truck style bell housing and other flywheels available, shown in 2nd pic- not included in this price. I also have an 833OD unit I may sell if you'd rather have the overdrive.
Located in Savannah, MO, hour north of Kansas City, local pickup only.
