850 DPer with Annulars?
i'm running a 750 dp with choke milled, with annular boosters, around 420 hp on a 360 j heads, runs great, i think if you got that carb you would have to jet the primary way down to around 70.
I was going to add a PF MB to my 750 vs., but i can get a base plate & MBs fairly cheap, so i'm thinking of going DPer, was looking on ebay & as you know, you will come accross alot of stuff, this just caught my eye, i'm sure it'll be too much, but the price is nice, so you are happy with the Annular boosters on the 750?
I can do up a PF MB (DPer) for around 250.00 useing some of my parts. But on the other hand i can do the 750vs. for 100.00 or so less with the PF MB, just pondering if the extra $$ is worth going too the DPer.
runs great in my 360, i have a 4,400 stall 3.55 gear. i would like to try a bigger holley, and infact i'm going to try a 910 cfm t-quad. i am sure you would have to replace the pri jets to 70 or even smaller, the annular boosters pull a way better signal on the jets so they are not comparable to carbs that are downleg or straight.
