[WANTED] 87 v8 hydraulic clutch bellhousing
If you want it to have the A-833 mounting pattern that is one rare item. My '87 V8 4 spd. OD Pickup is still mechanical linkage. I've always been under the impression that '88 was the first year for the hydraulic clutch bell housing. If your going to modify it, perhaps by milling off 3/8" from the trans mounting surface and welding a plate on it redrilled to accept a tremec or other trans, the 3.9L V6 in early Dakotas bolts to the LA318, uses the same 130 tooth flywheel, but the mounting pattern for the trany is for the NV2500? 5 spd. That bellhousing is far more common and easier to find. I do know a third party that has an '88 LA hydraulic bell housing but it is for the heavy duty NP235? type 4 spd. and would have to be modified for an A-833.
