I have access to all the under hood AC components from an 89 Dodge regular cab pick up that I am considering using under the hood of my 74 Duster factory A/C car. Does anyone have any thoughts on doing this.
I don't have it yet so I haven't looked at the fit of the condenser, but I think that should be the only possible issue. They both have LA small blocks, so the accessory drive should work, even if I have to go to the newer style alternator that should be a plus also. I have a friend in the business that can build me any custom hoses I should need. From what I understand, the compressor used on these trucks is the same Sanden unit commonly swapped into vehicles.
Any thoughts?
Cley
Any thoughts?
Cley
