8mm plug wires for /6 electronic conversion
64V200conv
Active Member
Philadelphia, Pa
Does anyone know of a manufacturer that makes 8mm wires with the spark plug tube plug that can be used on an early /6 that is converted to electronic ignition? I have found a lot of wires but none have the tube plug. Thanks for reading this. Frank
I think Magnecor makes one? Their catalog says "refer" under the early slant engines. You may want to give them a call.
