Does anyone know what years will interchange? I want to add a factory trac lock or what ever they called it then to my current open diff. I am working on a 98 durango.
I did some digging, carrier seem to be split into two groups:
'83-older
'84-newer
I also noted a few sites that state the 2011-up carrier might be different.
If you plan to go used/junkyard sourced, be careful. Chrysler had a lot of problems with the 2002-2003 units breaking clutch pack clips. Diffs were on national backorder at one point back then.
