9" drum issues
TwistedPenta
Oak Hill WV
I have went through my brakes and gave them an inspection and adjusted them up. And my car is favoring the right side when braking. It will slide in loose gravel or grass. Pulls when braking on the road. I found a froze up wheel cylinder on the left rear and replaced it. All wheel cylinders are working properly in the driveway. I don't know what else to check. Any suggestions?
If the shoes are installed properly and I assume they are. Long and short on each side. Long shoe in the back. Then I would look at the left side. The side not working. Might be a deteriorated hose causing obstruction in the line. I have also see a corroded clamp squeeze the hose almost closed
