tnts72
73+ b body brake calipers new, with new hoses, new pads, $100 shipped.
72 Duster gauges, everything but the faceplate, all appreared to work fine before removed and in nice shape. Removed all the plastic shields / cardboard tubes and light covers. Original metal housing and circuit board also in nice shape. $75 shipped
Both fenders I pulled off the car, both I would call rough but fixible $100 for the pair.
Set of small bolt pattern 9" drums with small balljoint upper control arms as removed from this 72 Duster $100 + ride
Power steering box, pump, mounting brackets, and column coupler $150 + the ride, box has some slop and may need rebuilt - I went manual steering.
Also have a set of small bolt pattern american racing 14" rims and tires. They came on the car and one has a plug in the edge of the outside tread, 1 will most likely need replaced. Also have a set on 5 on 4" 1 or 1.25" wheel spacers. Have a couple 5 on 4" steel wheels with tires I will send with the American racing wheels and tires $300 pickup preferred.
Trim for vinyl top 4 pieces, two that run across the rear section of the roof and the two for the bottoms of the a pillars, this one came with the snakeskin top lol. $50 shipped for the trim
Have a rear bumper that is rust but straight, could be rechromed.
Have some other odds and ends - 2 barrel throttle linkage parts,
Prices are obo and prefer to do some trading. I have one other fender left over that is a 70-71 but the marker is shaved and 80% of the body work has been completed. Have too much in it to really sell it, but if someone really needs a fender I would work a trade. Some Sherman rear 1/4 skin material. Lower patch sections were used on this build.
I will get some pictures uploaded
Things I would be interested in trading for, SB mini starters, used SB a body headers, 2.5 flowmasters, led headlights, msd pro billet distributor, Holley carbs 650 dp or 670 street avenger, aftermarket 727 transmission pan, good rubber bumper pads for a Duster, sound deadener -for upcoming carpet installation, Moog offset problem solver bushings, new headlight adjuster screw set, Black steering wheel, bolt on hood scoop - 6 pack or hemi style, or a nice set of sill plates.
Just odds and ends stuff, and yes I am not opposed to adding cash to make deals. EBay profile is tntz79, have done a little buying and selling on here, but I don't hit the guys up for trader ratings
