scamp 408
this set up was modded for the 69 and older small block water pump set up. It moves the alt away from the head for more room. I used this set up with the cast iron pump and aluminum heads with no problems. The alt is a rebuilt unit and uses the external stk volt regulator. May be able to use on 70 and up with diff pulleys.alt comes with double pulley 150.+shipping. 07731
