[SOLD] 90 degree oil filter adapter
Pabuhr
Iowa
I have a cast iron 90 degree oil filter adapter from a 1970 Dart with a 318. Greasy, but will clean up nicely.
Located in N.E. Iowa
$65.00
might have more luck selling it if you sneak it into the dishwasher one evening when the wifey isn't watching ;)
Are the 4 holes in the bolt offset or are they drilled in a row around the bolt. Some of the early bolts were drilled in a row and tend to stretch from weakness and leak over time. I also have seen them break at the holes.
Can you post a better pic of the bolt standing up. Thanks Steve
