[FOR SALE] 904 Adapter Rings: 1960-1967 Torque Converter into 1968+ Crankshaft
slant six
Do More With Less
IRWIN
For sale is an annular adapter ring that permits the use of a 1967 and earlier (small hub torque converter) with a 1968 and later Slant 6 or LA Block engine.
$45 - Includes Shipping from 15642
Hello Ivan, I got your message, Last one I have in stock.
If anyone else would need one let me know, I can get more of them made.
Thanks!
Parts Back in stock.
Send me a message if you need a ring to install your 1967- older 904 behind a 1968 Newer Slant 6 or LA Block.
Thanks
Auto Trans adapter rings still available
- I also just had a few of the Manual transmission version of these rings made. allows the use of a 1968 and later slant 6 flywheel to be used on a 1960-1967 Slant six crankshaft. I will pick those up from the machine shop this week.
The manual transmission rings may also work with LA engines
- I am not sure if the LA cranks / flywheels have the Same interchangeability problems as slant 6's.. if they do the manual rings will work for those too.
