mikes68gts
Member
wanted, need a driveshaft yoke for a 904 non lock up trans. 26 spline,5 in. barrel length, cap size 1 1/16 in., u joint, 2 1/8 width inside dimension, 3 1/4 outside, 7 in. from end of barrel to center of cap, I have 3 but none will slide in the trans. the yoke fits on the splines but the barrel diameter is to big. mine are all 1.558, but I need one with a smaller barrel diameter. anyone have one with a smaller barrel diameter? please let me know thanks, mike
