Sorry for the confusing terms. Let me start over. I'm trying to set input shaft end play but don't know what thrust washers to change. I have the front and rear clutch pack clearances already set.
I have the trans on a bench, pan side down with the pump and flat gasket in place and torqued down.
I first measured about .013" end play. I'm positive the front clutch tangs are fully engaged in the sun gear shell, meaning all clutch discs are engaged correctly in the rear clutch pack. My 727 manual says to change the thrust washer between the pump and front clutch retainer, I cannot do this because it is already at it's smallest thickness. I then checked the washer between the 2 clutch retainers and it is a large .090 washer. I swaped it for a .070 washer. Checked endplay and it was .040"
Fishy, are you saying I need a .062 washer between the 2 packs and only change the washer between the front pump and front clutch pack?
