We used an engine hoist to change the oil pan gasket, fuel filter gasket and oil pump gasket. The transmission was jammed up against the engine bay and now I'm concerned that we've screwed something up.
The transmission is giving a good jolt when it shifts from 1st to 2nd gear and doesn't want to shift into 3rd. I have to let off the gas a little for it to shift into 3rd. :banghead:
Is there an adjustment that is off now? Any other suggestions?
THANKS!!!
THANKS!!!
