rick1062
Active Member
I am working on a 1965 Barracuda with a 904 torque flight, stock floor console shift. The problem is:
With the car parked, I start it up and move the shifter out of park and into drive. Sometimes it feels like the park pawl does not pull far enough out, so it is bearly stuck in park but also in drive at the same time, if that is possible, and it won't move. If i give it some throttle I can feel the engine load up, kind of like if you held the brake on hard and put the trans in gear and throttled up. If I then move the shifter back and forth a few times, it seems like it will come out of park and work fine. It drives fine and all seems well. This may happen maybe 1 out of 10 times trying to take off after being in park. I may be in left field, but would sure appreciate some ideas.
It has been this way since I installed the transmission about 6 months ago.:banghead:
It is a very dependable daily driver, except for this issue.
Thanks as always,
Rick
Thanks as always,
Rick
