swing69
fightin' socialism
I have a 904 auto and 318 in the 65 Barracuda. so the orig. cable shifter set up is useless.
I have a used Mr.Gasket shifter with the twin loop/pull lockout for the R and Park - but Im missing some attachement hardware.
to keep things simple, what is the recommend easiest / cleanest shifter and install?
lining things up, it looks like the cable should exit the tunnel on the passenger side, loop around and come back on the dirvers side. its that right?
Picts and part numbers work great! Its for a reg. street driven car. thanks
