Question for the trans guru's.
I have 73 Dart 318 904. Has had Lokar kick down and throttle cable hooked up. I believe the kick down is adjusted properly, free at idle moves with throttle. Also has had a torque converter replaced, not sure of stall.
This car was raced, had NOS and other things done to it, manual valve body? Not sure.
Problem is I have no 2 or D. I do have low and reverse. I did have d a couple times but not consistent.
What could the problems be? Kick down adjustment? and what else. Pressure? Stall too high? Other areas to look?
Thanks
Just got back from a drive and if I manually shift into 2 it will slam you back into the seat. But I am unable to start out in 2 or d just 1.
Thanks
