TheCraigMachine
My 69 model 904 completely lost second gear the other night after a few sluggish feeling 1-2 shifts. Still has first, third, and reverse, but second just freewheels. Looking at the sequence of operations on the trans, its obvious that the kickdown band isnt applying, but as far as I can tell, the rear clutch pack should remain engaged even if the kickdown band doesnt apply on the front drum since the rear clutch pack stays engaged any time the trans is in any forward gear. This should cause the trans to more or less stay in first without shifting into second after the shift point has been reached. The way I understand it, the only way I could be losing BOTH the front band apply AND the rear clutch apply is through a massive pressure loss via the kickdown servo, like maybe a blown O ring???
The only mods to the trans is the addition of a TF-1 kit.
Needless to say, im about to start a rebuild. Just wondering what problem I should be looking for on this thing.
