bamacuda
First, let me say I know very little about transmission internals. That being said, I have a 65 model 904 that was rebuilt by a local shop about 2 years ago with a mild shift kit. It has sat on a rolling pallet in my garage ever since. I am getting close to installing it behind a commando 273. I stood it up to clean it and paint it and noticed a part missing. It was a small cover on the bottom of the tail-shaft part. I happen to have a parts tranny and took the one off of it. I need to know how to put it on ( I believe it is the kick down). There is a plunger with a spring inside. I can see that it has a "t" on the end of the plunger and the spring looks like it should hook onto the part sticking out of the tranny. I need some advice on how to reinstall this correctly.
Next, i have a stock 904 convertor and wanted to know what i need to do to it to have it ready (service? flushed? ???)
On the tranny, i have the one that I took out of the car so i know where everything goes as far as cooler lines, speedo cable, linkages, etc.
Thanks in advance for your help!!!:cheers:
