Rodzilla
I'm just getting my 904 back together and one of the assemblies I forgot to take pics of while disassembling is the rear clutch. To start I got the new seals on the piston (in the correct direction) then on top of that is the belleview spring and the the wave snap ring. Well so far this leaves a .100" gap between spring and snap ring. Is that correct? On a 727 they put a spacer ring in to close this gap and why would my 904 have this gap? The pic attached shows the piston in and belleview spring on top, then you can see it's about .100" above that to the snap ring groove. Is that correct? Run with a spacer or no? When I set up the clutch assembly on top I get a good clearance of .038". But none of that is affected by what's going on below the wave snap ring under the clutch pack.
Maybe there is always enough pressure at the backside of the piston that the slack comes out even when not engaged?
Thoughts anyone? Sorry about big pic but I wanted detail to show up.
