discharger1332
i recently aquired a 72 swinger with a /6 and 904 from a 68 barracuda. the p.o. could not get the engine swap figured out and sold it with the 68 stuff installed but not all buttoned up. he said he never took the shift linkage out of the car. So i went ahead and hooked up the shift linkage and it seems like the pattern is backwards. the only neutral gear is D.
I read on here that in 68 park is all the way back on the lever. did that change by 72?
or is my linkage backwards somehow?
when the shifter in the car is in P the lever on the trans is all way forward.
thnax for any input and advice.
the car is not running yet so i can not really confirm what the gear the tranny is in, but do not want to try and start it in 1.
