904 slip yoke issue
SlantedDart
Michigan
Hello. Trying to sort out an issue with my slant 6 904 68 Dart. Someone swapped in a 8-3/4 and drive shaft seemed to short. After trying to take it out the drive shaft was only engaged 3/4 ish inches.. tried to push it in more and it was jammed in pretty good. Also had wicked deceleration vibration. Upon inspection the tail shaft bushing was scuffed up.. so question is.. is the slip yoke diameter wrong size (new to Mopar’s) orrr tail shaft bushing wrong size. Did try a challenger drive shaft laying around and it did the same thing. Thanks!
