[SOLD] 904 street/strip trans Small Block Mopar
dart540
south western PA.
Rating - 70%
7   3   0
76- 904 street/strip trans
Just rebuilt no runs or start up
T/A Rev. manual valve body W/ special spring to boost line pressure
Stock Drum Fitted w/5 Alto red clutches and kolene steels,seals,gaskets,bushings
All new springs,rollers in factory sprag
Modified rev.piston,oiling system,front pump
No gov.,deep pan,5.0 lever
New high gear kevlar reinforced flex band,New Double Wrap rear band
New CRT spring pack,Reinforced band strut
4-pinnion steel planets
PRICE REDUCED $ 1,050.00 + 1/2 shipping.
Thanks Stan
Checking pump fitting in case and bolting up prior to final assembly without input shaft,bands,or drums.
Thanks Stan.
904 Transmission Sold.
Thanks FABO
Other transmissions available 727 for small block & big block and 904 for small block pm for your needs.
Thanks Stan.
