904 trans throttle kickdown cable conversion
Twister_71
New Member
Windsor ontario
Hey all,
I have a 71 twister, 318 w/904 trans and holley 4bl carb. I would like to convert to throttle and kickdown cables rather than keep the original linkage. Reason for doing so is because the mounting bolt for kickdown lever on the transmission is broken off flush and seized in. Would like recommendations on which aftermarket parts would be good for this. I really only need the kickdown but figured I would change both because I'm guessing they would come with a throttle/kickdown lever for carburetor. Would like feedback on anyone who has done this conversion. Any help with this is appreciated.
Thank you
I used Spectre on my 904. Found it at Auto Zone.Summit,Jegs also. Only $30 last time I checked.
