904 upshifting
Retroboy
South Australia
Howdy I have a 904 with a shorty kit, Transact Manual trans brake valve body, 5000 Turbo Action converter in a SBM powered FED. It's a three and a half hour drive to a track for testing. Trans shifts up OK on jacks, but on a quite country back road I couldn't feel it shift. There are serious limitations with that type of test track. Why when I shift with the vehicle on the ground can't I feel it? Is it because I need to be well over the converter stall speed? I've been a clutch guy in the past and I'm not familiar with converter equipped cars.
Cheers
You'll likely not feel it shift with that high of a stall. Have you tried it under WOT?
Not properly as I said there is severe limitations on my country road test track. Just looking to avoid a 7 hour round trip if it's not right.
Cheers
Do you have a tach? Can't you see some variance there?
