[SOLD] 915 J SMALL BLOCK HEADS
Jeremy
Santa Fe
915 J HEADS. STAINLESS VALVES, BRONZE GUIDES, 3 ANGLE VALVE JOB, MILLED TO JUST OVER 65 CC'S, MILLED INTAKE SIDE TO REDUCE INTAKE VOLUME, MAY NEED THICK INTAKE GASKETS, NASCAR VALVE SPRINGS, MOLY 10 DEGREE RETAINERS AND KEEPERS, NHRA STOCKER HEADS.
USED VERY LITTLE.. $600.00 PLUS SHIPPING.
What are the specs on a NASCAR spring? Heat riser passage blocked off?
Any porting, I don't understand how the intake side is milled to reduce the intake volume?
The more you mill the intake side the smaller the port. Makes a difference when you have to meet a spec.
Springs are strong.
Heat riser is blocked. Forgot spring specs. No visable porting. A little under valves.
