95 od trans to 1973 la motor
69DARTS
69 Darts Rule
indiana
ok i will be using an od trans on a 73 360 la motor
what flex plate do i need, can i use the lockup torque convertor ?
You'll need a 360 lock up converter and flex plate .
Yes you can use the lock up feature and O/D by adding 2 switches to power the lock up and o/d. You have to do this manually.
I think someone makes a control unit for this in the aftermarket that will do this automatically.
BTW you'll have to cut up the floor and fab a trans mount .
I'd go with a built 998 and GearVendors . No mount fab, just some metal massaging for the GV.
