d55dave
Hey guys, if I can get help anywhere I know it is here.
Our old voyager daily driver has developed (no surprise right?) a transmission issue. A little history - the van is a 3.3 4 speed overdrive and has 340,000 km's. Aprox 100,000 km's ago a rocker pedestal fractured off one of the heads so I replaced the engine and transmission with wrecking yard ones - I got a smoking deal on the drivetrain from a write off 97 Voyager. The transmission had obviously been recently rebuilt and had a new torque converter. It has worked flawlessly until this week, and only ever had ATF+3 or +4.
I know these transmissions are prone to issues, and aside from the differential pin issue I would suspect that thousands of them have been rebuilt when they didn't require it, due to a misdiagnosed sensor or computer issue.
Currently I am out of town but am trying to diagnose this over long distance so I can fix it when I get home.
The fluid level and condition are good, here are the symptoms. Everything seems fine and normal until the transmission shifts into high gear, at which point the transmission seems to slip (or engine freewheels?), with the revs climbing. When this happens the tach drops to a very low reading.
It would seem to me that this is the transmission entering limp mode, and after some research on the net I am guessing the input speed sensor is bad - causing the erratic tach readings and slippage as the computer does not know what is going on.
When I get home I plan to drop the pan, inspect for obvious metal / clutch and band wear debris, and try a new input sensor.
Sadly, we will not be able to afford to replace this van for another 6 months so I need to try and keep it running for a few more miles.
Any thoughts or input from any transmission experts?
