[WANTED] A-500 Brackets
68coupe
I need A-500 cable style transmission brackets. I need the bracket that holds the kickdown cable, the kickdown/shift lever, the bracket for the return spring and the spring. Thanks
I have the cable and spring brackets. The TV/kick down bracket in the pic appears to be from a van. What are you trying to put them in?
I'm connecting the throttle valve cable from a 5.2 magnum throttle body to a 904 transmission. The picture of the brackets came from someone that's done a magnum swap. I understand I need brackets from a 904 based transmission - A-500, 40RH, 40RE, 42RH and 42RE, 44RE. Please correct me if I'm wrong.
If you have them, please PM me with cost and and shipping. Thanks
